Guest hannje Report post Posted 01/11/2005 04:20 PM Trying to schedule an outdial, putting the following xml file into data directory <OutDialEntry> <LineSelection>dxxxB1C4</LineSelection> <PhoneNumber>2146190990</PhoneNumber> <OnAnswer>C:\ttstemp1.wav </OnAnswer> <OnAnswerMachine>C:\ttstemp1.wav </OnAnswerMachine> <AnnounceMessage>none </AnnounceMessage> </OutDialEntry> VoiceGuide dials the number, but never plays the wav file. Looking at trace, it looks like it's expecting a script file, not a wav file. Your documentation seems to indicate either a wav or a script file will do. Any ideas? Thanks 101430.05 8 rv add [$RV_CALLEDNUMBER]{2146190990} 101430.05 0 dial callque delete id=37 101430.05 8 AddRVns [OutDial_Result]{Contacted_Human} 101430.06 8 Live person answered, starting C:\ttstemp1.wav 101430.06 2 tr NewVgsVgm_Goto C:\ttstemp1.wav ,,,,,0 101430.06 8 rv add [scriptEnd_Time]{1/11/2005 10:14:30 AM} 101430.06 8 rv add [scriptEnd_Goto_Script]{C:\ttstemp1.wav } 101430.08 8 rv add [scriptEnd_Goto_Module]{} 101430.08 8 rv add [scriptStart_Time]{1/11/2005 10:14:30 AM} 101430.08 8 rv add [scriptStart_CalledFrom_Module]{Hangup the Call 127} 101430.09 0 Script Load C:\ttstemp1.wav 101430.13 -1 ERROR 5.2.3018 VgsScriptLoad [C:\ttstemp1.wav ] line:0, 62:Input past end of file 101430.13 8 Loaded C:\ttstemp1.wav into:-9 101430.14 8 AddRVns [scriptPath]{} 101430.14 8 ERROR 5.2.3018 Could not load script C:\ttstemp1.wav 101430.16 8 Connected_OutgoingCall NewVgsVgm_Goto=>Error: NewVgsVgm_Goto_Setup failed 101430.17 0 dial callque update id=37 next call time 0501111019 101430.19 0 dial callque DB update returned 101430.20 8 timer set 1 EV_TIMEOUT_HANGUP 101431.20 8 timer fired EV_TIMEOUT_HANGUP 101431.20 8 ScriptEventCode 9001 iLineState=5200 101431.22 8 LsWaitAfterDialingOut EV_TIMEOUT_HANGUP 101431.22 8 rv add [Hangup Time]{1/11/2005 10:14:31 AM} 101431.23 8 Hanging up call... [LsWaitAfterDialingOut] 101431.25 8 RecSoundStop ok 101431.27 8 PlaySoundStop err=0 101431.28 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 101431.28 8 fnHangupCall end 101431.31 8 linedevstate 2048 0 0 101431.33 8 callstate IDLE 66016 0 0 101431.33 8 WorkingMode@Idle= 101431.34 8 timer clear Share this post Link to post
SupportTeam Report post Posted 01/11/2005 09:07 PM We'll look into this problem. In the meantime can you please specify a VoiceGuide script for both the <OnAnswer> and <OnAnswerMachine> fields. To just play a single sound files just use a script which had a single play module, and specify the sound file from within that module. As an alternative you could specify a Result Variable in the Play module, and then specify the contents of that Result Variable in the <RV> field when loading the file. This will allow you to select the sound file to be played from within the OutDial_New.xml Share this post Link to post
Guest hannje Report post Posted 01/11/2005 09:28 PM thanks - that's exactly what I did - threw a baby script together, passed it the name of the wav file in the RV field of the xml file, and every thing works as required. Share this post Link to post
